I just recieved my first results after switching to Amsoil 0W30 and I am a bit concerned about the increase in Iron, Lead and Aluminum.
Vehicle is located in Northern Michigan, garaged and driven about 15 miles each way to work on paved rural roads and for occasional trips under 250 miles.
Results below
Comp. Descr.: V8 ENGINE Fuel Type: Gasoline
Oil Brand: First:QS Second:AMSOIL
Oil Type: First
eluxe Second:S2000 SYN ENG
Equip. Make: 2002 TOYOTA Fluid Grade: First:5W30 Second:0W30
Equip. Model: TUNDRA Sr5 4X4 4.7L
SPECTROCHEMICAL ANALYSIS (ppm)
Miles on Unit
6646 11479
Iron 3 47
Chromium 0 1
Lead 0 11
Copper 13 37
Tin 0 0
Aluminum 0 10
Nickel 0 0
Silver 0 0
Silicon 15 29
Boron 32 3
Sodium 0 2
Magnesium 80 340
Calcium 1244 2792
Barium 0 0
Phosphorus 934 1034
Zinc 1108 1221
Molybdenum 7 4
Titanium 0 0
Vanadium 0 0
Potassium NA 0
Physical Properties
Fuel Visc40 NA NA
Visc100 8.5 10.71
Water 0.05 0
Soot/Solids NA NA
Glycol Neg Neg
Additional Tests
CHANGED YES NO
NITR 10.0 19.0
OXID 5.6 22.0
TAN NA NA
TBN 7.6 5.84
Analysis Recommendations
Second analysis 75317 RESULTS OF TEST PERFORMED INDICATE NO CORRECTIVE ACTION REQUIRED.
First analysis 297214 VISCOSITY IS OUT OF INDICATED GRADE NORMAL WEAR INDICATED RESAMPLE AT NEXT REGULAR INTERVAL
Notes added:
Factory oil changed at about 1500 miles to QS 5W-30 and Fram filter.
QS oil changed at about 5000 miles to Amsoil Series 2000 0W-30 and SDF 15 filter.
First analysis performed by OAI in Superior WI as a baseline
Second analysis performed by new lab in Cleveland OH
[ May 06, 2003, 06:20 AM: Message edited by: Patman ]
Results below
Oil Type: First
Miles on Unit
6646 11479
Iron 3 47
Chromium 0 1
Lead 0 11
Copper 13 37
Tin 0 0
Aluminum 0 10
Nickel 0 0
Silver 0 0
Silicon 15 29
Boron 32 3
Sodium 0 2
Magnesium 80 340
Calcium 1244 2792
Barium 0 0
Phosphorus 934 1034
Zinc 1108 1221
Molybdenum 7 4
Titanium 0 0
Vanadium 0 0
Potassium NA 0
Physical Properties
Fuel Visc40 NA NA
Visc100 8.5 10.71
Water 0.05 0
Soot/Solids NA NA
Glycol Neg Neg
Additional Tests
CHANGED YES NO
NITR 10.0 19.0
OXID 5.6 22.0
TAN NA NA
TBN 7.6 5.84
Notes added:
