Gents;
Haven't posted on here in awhile...but for the last 3 years I have been running Amsoil 0W-20 in my Hondas (2006 CR-V, 2006 Civic)...1 year OCIs, up to 10K miles. Did an analysis a couple of years ago and got an "all clear" from Blackstone.
I'm nearing the end of another one year interval and getting concerned about some varnishing and a softer brown oil coating visible through the filler holes and on the dipsticks of both cars.
The Civic is worse...has that orange plastic dipstick and there is a solid black substance in all the nooks and crannies of it. Looking into the filler hole it is dark, and there is a little bit of a solid substance on the filler cap threads that I can scrape off with my fingernail. Reminds me of the stuff you clean off the inner parts of a gun, but not as hard to remove. From the underside of the cap I was able to wipe off a mixture of soft brown coating and solid black residue.
The CR-V has some black crud on the filler cap threads too, and a soft brown coating on the non-contact areas under the valve cover that I can see through the filler hole. There is a flat spot just under the cap and I was able to wipe the brown crud off that with a finger to reveal silver metal. The dipstick also had a brown tint that I could wipe or scrape off.
What do you make of this? Oil cooking in the Virginia heat? I noticed the black deposits forming on the Civic's dipstick and on the filler cap almost immediately after I started using the Amsoil 0W-20...but my first analysis came back good so I stuck with it. Mistake? Or am I being paranoid?
As I said, I'm under 10K miles and just about 11 months on this interval for both cars (45K total on both). Using the EaO13 filter.
PS: I am not trying to bash Amsoil here, until I started seeing this I have been very happy with it!
