Ams and Molybdenum?
NJ
Is there any reason Amsoil doesnt use Molybdenum? I went back and read prior discussions on the Moly issue, but I didnt see any that talked about this. thanks
[ November 25, 2002, 07:09 PM: Message edited by: buster ]
I'd suspect they like what they have and feel it isn't needed, which you can go on both sides of the fence on that one, but also Moly is expensive so imagine the cost of that oil if adding moly.. same as redline maybe?
Amsoil does essentially the same thing with various types of organic esters in the basestock blend. The only product they use moly in as a solid film lube is their HD synthetic grease ....
I believe it's a matter of additive levels and differing philosophy about formulated lubricants.
Amsoil depends heavily on ZDDP as the anti-wear/EP additive and PAO's and polyol esters as their FM additives.
Redline and Mobil attempts to cover all bases with PAO's, polyol and advanced esters as FM's, and moly and ZDDP as AW/EP's.
Schaeffer's doesn't use polyol esters so it depends on a mix of multifunctional additives such as moly, antimony and ELCA's to provide AW/EP and FM functionality.
I do recall being at an Amsoil meeting with my BIL and hearing Al and other's claim they would never put solids in a formulated engine oil. Of course, they also stated that none of their oils would ever contain petroleum base oils, except for minor carrier oils.
Of course, we know that has changed, too!
[ November 26, 2002, 05:31 PM: Message edited by: MolaKule ]
Thanks again. Just wasn't sure what the deal was with it.
I believe it should read," Amsoil tries to do the same thing ... etc not," it does as organic esters in basestock blends" because you're talking hydrodynamic vers barrier additive. The only thing comparable that I see to moly would be zddp used by amsoil.
Official Patman prediction:
Amsoil will be using moly in it's formula within the next two years.
Mark my words.
I agree with Patman, and Al will say he was "the first".....and the scary thing is he'll figure a way to be semantically correct....
Do I love this guy, or what?
Mark my words.
I beat you to it in another thread
EDIT:
It was not official so you got me!
Patman 1
dragboat 0
[ November 26, 2002, 07:31 AM: Message edited by: dragboat ]
FM is Friction Modifier.
There is an explanation of FM's and AW's in the Interesting Articles thread.
Cheers!
Patman,
Amsoil and Lubrizol work very closely to develop their additive chemistries and I don't think they feel the need to add moly, teflon, graphite or any other solid film additive to an engine oil. If/when they come out with a 0w-20 synthetic, they might add a small amount of moly as a friction modifier, but I can't see them using it across the board.
It does make sense from the standpoint of formulation chemistry to use moly in a petroleum oil with a low level of ZDDP, ie a phosphorus level < 1000 ppm. I can clearly see the benefit in that case ....
If the GF-4 oils really cap Phosphorus @ 500 ppm, then all bets are off and it will be very interesting to see what happens.
I won't be using those oils if they keep that cap!
TooSlick--
Is Molybdenum Trialkyldithiocarbamate a solid film lubricant? That's the moly we're talking about in PCMO, not MoS2.
Slider--
It is indeed likely you won't use GF-4 oils unless you get a new car 'cuz they might not be backward compatable.
Ken
Mark my words.
It has been more than a few years, is there any moly in any Amsoil oils?
Originally Posted By: 84zmyfavorite
Please, EveryOne who uses or is thinking of using Amsoil, Stop.
First clown on my ignore list
