Amazon Fuel Filters
I found this:
150 Micron Fuel Filters
I seem to use these things quite a bit as well as the white 75 micron filters. I'm sure these are knockoffs. Has anyone used these before? The two pieces look to be butt joined as opposed to a Briggs or Stens which is lap joined.
I've used them, with no problems to report. I paid about a little under $2 each IIRC buying them one at a time.
Looks like a good cheap way to get large debri out of the carb. You will probably know when its time to replace it if it starts to leak. For the price you can just change it 1/year and be done with it.
