allison report
sdan27
Michigan
Looks like it worked. I did an oil analysis on three allison tranmissions we run and they all came back nearly the same. The only difference was this one was run 800 hours and the others were 300. I did not change the oil in them but replaced the filter and installed a better filter/header combo. I basically installed what the allison part breakdown called for. If the oil is fine otherwise, why replace the oil if I can just filter it better?
sdan27
Michigan
i tried to look again and found it's not working so well. how do you get a report up on there?
sdan27
Michigan
All right, I'll do it this way. This is in an MT653 Allison with 890 hours on the oil. We're using Texaco Heavy Duty Synthetic ATF. Al 8 Chromium 0 Iron 112 Cu 16 Tin 4 Moly 0 Nickel 0 Mag 0 Silver 0 Titanium 0 Potassium 0 Boron 49 Silicon 5 Sodium 8 Calcium 278 Mag 4 Phos 467 Zinc 29 Barium 0 Insolubles % .1
