Has anyone come across any ISO 5011 tests or flow tests comparing the Airaid dry vs oiled filters?
I've got a 2014 SHO with the 3.5 EcoBoost running a tune that needs over 700 cfm of air. I suspect the stock airbox is a restriction for a number of reasons. One, it is the same one used on a 2007 Edge and while it might flow enough for the twin turbos at extra boost, it could be restrictive enough to explain the sharp drop in Short term fuel trim above 5400 RPM.
I looked at the Airaid dry and oiled filters for their "cold" air intake and the dry seems very restrictive, about as bad as AEM. It won't even pass the unofficial and unscientific hair dryer test that the paper and oiled filters pass.
