Borrowed From another Topic:
My daughter's 99 Ford Ranger. Inspecting the brake pads yesterday. Jackstands under the frame, wheels off.
I turned the wheel lock to lock --engine off --to get a view of front and back of both calipers.
After a couple times in and out of the truck there was steering fluid on the ground.
It had somehow forced itself back up into the pump and overflowed, and pushed the screw cap loose.
I had never had anything like this happen, or heard to watch out for it.
When started, the steering was very rough, and made noise like a lot of air was in it. HUH ?
I drove it around several times, tight turns, etc. When I stopped, a lot of small bubbles were coming out in the reservoir. I let that happen for about 15 minutes, and topped it off with some new fluid, and I think it is OK now.
Anybody seen this, or have a theory ?
Odd thing.quote:
Originally posted by drive it forever:
To purge the air out of the system, jack the car up, turn the wheel lock to lock 3 times with the car off, check fluid leval add if needed, start car, keeping at 2k rpm's, turn the wheel slowly lock to lock 10 times, let the car idle 3 minutes and shut off, lower the car and check the fluid leval again.
