Ok my AC system has a couple leaks(that I know of)
The first one it between the compressor where it fits onto the steel hose of the low side. I know its there since I did a dye charge with envirosafe and it clearly shows the dye there. I tried an auto glue called "Seal All" but it doesnt work. Anyone know if an adhesive that can handle this job?
Also, the high side valve. I dont think its supposed to loudly hiss when you take off the dust cap is it?
The system was R12 originally and the previous owner put the 134 adapters on it. I thought maybe the adapter was just bad, so I removed it and placed on the new one that came with my Duracool kit. Well this one was MUCH different than my current one. When I took it off I see a schrader(sp?) valve(looks like a tire valve). The new one I screwed on no longer has a needle in it that works with the schrader. If that made sense. I think maybe my OEM equipment has a leak in the schrader valve on it, can I find another one to screw onto it to correct that leak?
The leaks are so bad in those 2 places I lose full charge in under 3 days. Thats why I switched to duracool, cheaper and safer for the system than 134a is.
