Been thinking. What size or how could I set up a system that will use my 7 gallon portable air tank and a compressor also? Have it set up that the compressor will pump to the tank, when the tank get's full, regulator kicks in and shuts off the pump. If I need it in the garage, attach a quick connect to it, if I need the tank, I disconnect the quick connect on the regulator side and then remove the tank. What are the best or good type of compressor? Would a 7 gallon tank be big enough so that someday if I decide to go air compressor tools, would that give me enough volume? What cfm should I look at? There are just tons of these things for sale and I really would hate to buy one with a tank when I have a perfectly good tank already, plus it's 7 gallons, a lot bigger than the 100 to 200 dollar price range for what you get. Anyone??
