Air compressor clicks
Hello, I have a Northern tool air compressor that when I tried to start it, it clicks, you can see in the video
It’s a electric air compressor all I can post is a picture and not a video
Is that some kind of reset switch above the pressure switch ? Check the capacitor on the motor .
Push the reset button and see if it starts. Then ck the capacitor under the blue cover. While you are there take a meter and see if you have any power to the capacitor.
I support the capacitor suggestions. I doubt it is the breaker as you wouldn't even get a click out of it.
First make sure that it is plugged into a live outlet. The switch will click when you move the lever even without electricity.
The reset button does not work like it did, so it’s kinda like in a loose mode with no clicking if that makes sense
^ How does that identify whether it's the switch or something else besides the motor winding? I'd check the switch first, because it was reported as not feeling right.
That's why I said to jump out the switch first . Testing things with an ohmmeter while they are still wired in the circuit can be misleading .
