Good day everyone.
I have Agri-Fab pull behind my mower leaf vacuum with Briggs 900 series 205cc motor. Plastic timing gear on that motor is toast. They don't make them anymore and I will need to buy a whole crankshaft assembly for $179+shipping to make it work again. That made me look in to getting a Predator 6.5 HP 212 CC motor for $149 and making small shaft adjustment to make the impeller work. Today I was about to pull the trigger on that motor when I noticed 8hp 301cc motor on the shelve for a little more. Would extra power be beneficial for a leaf vacuum? Would it be worth upgrading or just stick close to the stock? They are both about the same RPM's. Both will require some welding to get impeller on.
