AGM Height Adapter '15 Camry XLE 4-cylinder
northern Alabama
So O'Reilly doesn't know what part number battery height adapter is required for their Super Start AGM Platinum battery model 35PLT on a 2015 Camry 4-cylinder XLE. Does anyone else know where to get this?
Thanks.
This is the closest spacer that you will be able to find that should work: Odyssey Battery Spacer
It is an inch longer than the Group 35 battery, but will fit in your battery tray which originally came with a Group 24F battery. One of the reviewers stated that he used the Odyssey spacer to install a Group 35 battery in place of a 24F in a Nissan 370Z.
Otherwise, you will either need to reach out to East Penn who makes the SuperStart AGM batteries or try to get one off a used returned core at O'Reilly's, AutoZone, Advance Auto or NAPA.
Thanks
It should come with it? Although in our region we recently replaced carrying 35PLT with 35PLTJ which is the correct height and doesn’t require an adapter.
If you lost it, go back to the store and ask for someone to look on the core battery pallet and see if there are any floating around there.
Really anything that’s close will work.
Does this Camry use the goofy Toyota tie-down where one end bolts to the radiator support? If so, a lot of "aftermarket" Group 35 batteries will not fit perfectly.
