Aftermarket wheels for Ford Escape
Waterloo, ON
I have a chance to buy some aftermarket Aluminum wheels for my Ford Escape. The bolt pattern is correct, but the hole in the center of the rim is larger than the hole in the stock rims.
Does this matter, or is the bolt pattern all I need to worry about?
You need to get a set of matching centering rings for it to work properly with your vehicle.
You also need to make sure the rim's offset is correct for your application.
