You gonna leave the neophyte hanging like that, or are you gonna explain the "seal issue" to him?quote:
Originally posted by haley10:
Just curious as to why you thought that an engine of this vintage with 250,000KM on it with dino would be able to run a syn with no problems?? You must have known about the seal issues.quote:
Originally posted by kickster:
before I ran dino 10W40 without any leak.
I dont think it is the thickness of oil that is causing the leak. winter time I had 10W30 and it didnt leak.
I don't think he's going to need an explanation at this point. All I know is that unless he bought it direct, some Amsoil salesman needs his arse kicked.quote:
I assume you were using dino 10W-40, not synthetic 10W-40? Dino 10W-40 is suggested only between -15 and +20 degr C in that engine. Dino 5W-30 is okay for lower than -10 degr C, but not above.quote:
If I were you I would care more for the motor than the oil.... if you own a car you have to WASTE money sometimes, but if you wanna get the most out of the car then either drain and fix or keep adding an oil like pennzoil until you have the money for proper repairs.quote:
I have a 1990 golf 1.8 8v. It has 250K KM on it.
3 weeks ago I switched to AMSOIL 5W50 and ever since it is leaking oil from the back of the engine.
May be just the age of the seal materials.
A lot of seals start leaking between 100-150 K miles. Amzoil may have cleaned wihout c0nditioning the seals, none the less with that many miles is is normal on most cars to start leaking. I'm no mechanic but I have traveled over 4 MILLION miles and do have REAL life experience.
Some of the adds do work and most do not.
If I were you I'd dump a good oil like pennZoil through there til you have the money to replace the seal and then give amzoil another shot.
JMHO
There is always a oil spot under my car ( cap full worth) it only leak while it is running. I have already replaced the valve cover gasket.
Then to me even more reason to suspect timing....
Yes the oil added may have speeeeeeeeeeed it up a little but usually the cover will leak before the pan but not the rear... IM-experience the rear will leak up to twice the gasket, but it's not set into stone. BUt:
Bottom line don't worry about it... fix the leak properly and when you do try it again and there should be no problems.
-----------snip---------
Is it worth adding an over the counter leak stop additives? ------sometimes depends on the additive-------
I cant use ARX since the oil is only 3 weeks old. I am not about to waste $50 worth of finr synthetic oil and Mann filter.
Ok, I'll buy that, probably what is the new Euro car formula.quote:
Sorry my mistake. It is 5W40 not 5W50.
