After 14,000 lug nuts I got Torque wrench calibrated
iowa
I have a 1/2 inch 250ftlb Precision Instruments spilt-beam torque wrench I paid about $200 15 years ago. Had it calibrated 8 years ago, and have torqued over 14000 lug nuts since. Even though it always felt right I tried not to worry about it, but figured since I have saved over $600 on yearly calibrations, it seemed spending $50 to get it checked would probably be worth it. Well, it checked out perfect with no adjustments needed. It actually improved over time in the 80-150 range I normally use. I will never buy a harbor freight torque wrench, when for a little more money in the long run, a quality tool can be cheaper to own. The best thing about the split-beam is there no need to constantly back it down to zero, which is probably why it has never needed any adjustments since new.
I've been looking at one of those in the 250ft range. Looks like what you have. I think i will get one!
Did you have a local place calibrate it? Or did you send it out?
I hate that, a PI split beam 1/2" is definitely on my tool list.
Originally Posted by E150GT
You count the lugs you tighten?
I can get close. Just count up how many tires you install in a year, multiply by 5. It is actually much higher than that with the 6-8 lug wheels, plus I quite often make another pass around the bolt pattern. I always come back to the first lug nut I torque and if it moves, I go around again. Watch out if it takes another pass to come up to torque. That could indicate a problem I've found out a few too many times.
I recently had my 48 year old Snapon 200 ft-lb click type wrench calibrated for the first time. It was off at the high end, by about 5.5%. Replacement of a $7 part and calibration afterwards brought it back within 3%. It has seen a lot less use than yours, for DIY stuff only.
a quality tool for sure thats a little more than a little more $$$, but a decent torque wrench is a good investment for sure. just looked a bit, not cheap but better than expected especially on e-bay. used + new from authorized distributors
You'll love this story....So, I get some 225/40r 18 and 255/35r18 Michelin PS4s for my BMW X1.
That's lower profile from 225/45r18 and 255/40r18, but I wanna buy and install at Discount Tire because of how good the service is.
They won't do it since the 255/35r18 has 1356 load rating instead of 1389....BS ....insignificant for tirE that is raTED TO 186 MPH.
So I go to the Ghetto Wheel World for installation where on can buy a $1400/wheel for $2800 on a years payment schedule.
Two workers mess with one car for 2 hours and then another for 2 hours. Finally they are on mine as store closing.
One guy runs up lugs with gun. while the longer working there guy TORQUES them.
I knew they were too tight, but went home. If I could have gotten them all off I'd forgetton the sloopy torquing.
Couldn't get a few so went back 2 weeks later, aND store manager was indignant! WE TORQUE ALL TO SPECS!
So I say try to break one with my manual indicater torque bar. He nearly falls over backwards, and say my bar is off.
Really cause I'min a wheelchair and I can easily take off lug torqued to the 88 ft/# specs of BMW?
So, I guess all these numbnuts can't reason. OF COURSE TORQUE WRENCH WILL POP OFF WHEN IT HITS 88 ft/#'s, but it can't measure the extra 100 ft/#'s!
Nice. This looks like my Snap-On unit from 20+ years ago that I still use regularly. I should probably have it re-calibrated at some point...
