since we don't have too many aircraft, i thought i would post this relatively disappointing OA from my HyperCheetah. engine is 119SMOH. my flight pattern is typically that after advancing the throttle to the stop, i put my foot on it to prevent slippage...
blackstone comments
For one reason or another, we found wear higher than it should be for your Cheetah engine after
running a routine 43-hours on the oil. We never know the "why" of things on a first sample. We would
guess we were seeing corrosion from inactivity but we could also be seeing wear-in if the engine has been
opened since zero hours. Universal averages show typical metals for this type engine after a 43-hour oil
use run. You can see the differences in wear, your engine to averages. If the oil filter is clean and local
inspection shows no faults, fly 43-more and recheck.
MI/HR-ON-OIL------43HR
MI/HR-ON-UNIT-----119SMOH
makeup............8 qts
ALUMINUM----------14
CHROMIUM----------11
IRON--------------57
COPPER------------19
LEAD--------------5576
TIN---------------9
MOLYBDENUM--------3
NICKEL------------12
MANGANESE---------1
SILVER------------0
TITANIUM----------0
POTASSIUM---------0
BORON-------------0
SILICON-----------20
SODIUM------------1
CALCIUM-----------5
MAGNESIUM---------4
PHOSPHORUS--------936
ZINC--------------8
BARIUM------------0
[email protected]
[email protected]
FLASHPOINT-IN-F---525
FUEL%------------- ANTIFREEZE%-------air cooled
WATER%------------0.0
INSOLUBLES%-------0.6
blackstone comments
TIN---------------9
MOLYBDENUM--------3
MANGANESE---------1
SILVER------------0
TITANIUM----------0
POTASSIUM---------0
BORON-------------0
SODIUM------------1
CALCIUM-----------5
MAGNESIUM---------4
ZINC--------------8
BARIUM------------0
[email protected]
[email protected]
