AEM DryFlow Filters (Polyester/Washable)
Silver Spring, MD (USA)
http://trucks.aempower.com/press_events_detail.asp?aid=54
quote:
Features:
• The DRYFLOW Synthetic filter’s unique non-woven polyester filter media is independently tested at over 98% initial filtration efficiency (99.4% cumulative efficiency) based on SAE J276 JUN93 Fine Dust Air Cleaner Test Code procedures. Oiled filter initial efficiency is typically 90% to 95% efficient.
• The DRYFLOW Synthetic filter delivers superior filtration and equal performance (compared to an oiled filter) on every BRUTE FORCE intake tested!
• AEM’s unique non-woven filter media never needs oil! This means less down time between cleanings and no more chance of over-oiling.
• A neutral gray filter color complements our mirror-polished and silver powdercoat finishes, and hides the dirt that it keeps out of your engine.
• A mineral reinforced plastic interior cage increases structural rigidity—it’s virtually impossible to collapse, even on Diesels! No mesh screen means no more filter damage from bumps during installation or cleaning and no corrosion damage.
• Element is cleanable and is Guaranteed for Life! (Filter Cleaning Solution included)
• Will NOT void your vehicle’s warranty!
Did a quick search for dryflow...didn't find any discussions on it. Thought you guys might want another debate topic!
Any comments?
Oh sorry...I searched
. Someone should edit the title of the previous thread to include "DryFlow"
Looks like the awnser to all our K&N fears! People constantly ask for a dry cone filter on car forums. I found a place that now sells them in a many different sizes, 5 or 8 inch long. Dry Flow These would be just the ticket for upgrading a cold air or short ram system to lose the swiss cheese oiled gause filter. Another sweet feature is the built in velocity stack. It has a lip on it so the intake pipe mounts flush against that lip, so the wall f the intake doesn't create sort of a ledge that air can create turbulence against.
I have that filter on a short ram that just arrived. Be aware that the cleaner is $10 per bottle, two bottles required per cleaning. OUCH!
