Hi guys,
I want to do the following to my 6G74 Diamante and was hoping to get advise in what sequence to do them.
1. Run fuel system cleaner, oil flush and change oil
2. Replace valve stem seals, clean lifters, replace injectors
Initially I wanted to do #2 first so then I could run fuel system cleaner and hopefully clean up valves etc from the oil getting past the valve seals, however I am a bit concerned about getting the lifters dirty again from the oil flush and hence thinking maybe it's better to do the flush first and then manually clean the lifters?
