My 08 IS F has a slight drift/pull to the right. After getting my alignment done, the front caster is slightly out of spec. Would this .2° cause a pull? I researched replacement LCA bushing, and I am thinking of replacing the right LCA bushing with P/N 48075-53020. The RH LCA bushing is a +20' /.33° adjustment. Would this LCA bushing take my RH Caster from 7.8° to 8.13°. I am trying to decide if balancing out the front Caster would fix my slight right pull/drift even though I would still be back at a .2° Caster difference.
Which bushing do you recommend to help improve my caster? Would it be wise to also replace the LH LCA bushing to bring it closer to 8.33°?
