The parking brake on my relatively new CR-V was acting strange so I thought I'd adjust it per the tech manual (long story).
The setup for the parking brake is a drum on the interior of the rear brake rotor (has rear disk brakes). It is non-self adjusting...there is a star wheel adjustment at the drum.
The major adjustment is at the drum using a screwdriver to first lock the shoes all the way out and then back off 8 clicks. When I did that, the shoes still seemed to 'drag', so I backed it off all the way but they still dragged! I figured I'd cut my losses and settle on 16 clicks. Could still hear it drag a bit, but not as bad.
Next for the 'minor' adjustment. This entails screwing a nut where the cable from the brake handle meets the cables for the individual brakes (the equalizer). The manual says to turn the nut until the shoes start to drag at '1 click' of the handle. Well, unfortunately that was meaningless for me since the shoes were already dragging with no clicks. So I pounded my head against the hood for a little bit.
My solution was to adjust the brake (minor adjustment at the equalizer) just to the point where it would hold the car on a hill, but not noticeably 'drag' when driving. Amazingly, I went a turn or two too far on the screw and could feel the brake shoes holding the car up. I backed off a couple of turns and it freed up, but fortunately still held the car on a hill.
Anyone else have parking brake horror stories? Seems like I was behind the 8 ball to begin with when I couldn't get the shoes not to drag on the first adjustment. It's like the guidance in the repair manual (genuine Honda) just didn't apply to me.
