Kestas
Staff member
Filterguy, I know your's was a rhetorical question, but I think warranty was 12 months/12,000 miles, whichever came first.
You don't add any extra oil. If your car takes 5qts with a filter change, you add 5qts whether you prefill or not. Simply put, nothing changes.quote:
Originally posted by ucandoit:
So would you just put the same amount of oil into the engine after filling the filter? If your car takes 4 quarts and you put 1/4 of a quart in the filter would you put the remaining 3 3/4 quarts into the crank case or 4 full quarts?
Might sound like a dumb question but I'd be interested to hear what people say. Also the engine per say isn't really "dry". At the very least there should still be a film or coating still on the parts from the previous oil...correct?
My 57 Chevy had no oil filter! Who knows what coursed through that engine!!... especially with the oil at that time!!!quote:
..The oil you put into the filter especially on the "clean" side has contaminant in it....
Refer to comment #1. Never prefilled a filter, never will. Ran many motors over 100k mi. without a lube-related failure. Different strokes for different folks, I guess...quote:
Originally posted by 99:
I prefill all of my filters. Always have, always will. Screw what the wannabe engineers have to say about it.
Knock yourslef out, dude. Personally, I don't have alot of time to waste on useless activities. BTW, I am an engineer. What do you do for a living?
I know my engines are quiet on startup after a oil change with a prefilled filter compared to not being prefilled.
Most of the noise referred to (bearings rapping is another issue altogether) is hydraulic lifters going down, which has little to do with lubrication in the few seconds after startup.![]()
That's one aspect the prefill naysayers seem to forget....the engine is essentially running dry for a few seconds until that filter fills up and sends oil out to the galleys.
I have a open diff sitting on piece of newspaper in the corner of my garage that is still oozing oil after sitting for a month.
Considering prefilling is so simple to do, I don't know why someone would choose not to; that is unless the filter is mounted upside down ZR1 style or totally horizontal, but both of those configurations are fairly rare these days. In the end, it's your engine, treat it how you want to.
I agree, I've prefilled, or primed, mine for years and always will. Even my Mazda6i, which has a cartridge style filter, I insert the filter in the holder and 'wet' the filter with fresh oil.quote:
Originally posted by bmwtechguy:
I fill my filters when possible to lessen the time that the engine runs with zero oil pressure.
Precisely what I do with my 454 pickup and '95 Civic. I'm a firm believer in pre-filling the filters whenever possible- I like seeing the gauge respond or light extinguish ASAP! The old Slant Six, unfortunately, has the filter "backwards", so I crank the engine for 15 seconds or so with the coil wire disconnected. It still raps a bit when it fires but every bit helps...!quote:
Originally posted by Tremo:
My Chev V8 has a vertical filter. I always fill it up when I change the oil.
My wife's Escort has a horizontal filter. I add anough to wet the media, but not enough to run out and make a mess when I'm installing it.
That's true - but with the oil filter already "filled" to an extent, it will take less time for the oil pump to pressurize the system because some of the space it needs to fill, is already holding oil.quote:
Originally posted by darryld13:
I thought that since oil pumps are positive displacement, that meant that oil did not move through the engine without the oil pump providing pressure? If so, then wouldn't the prefilled oil in the filter not move until the oil pump has pressurized the system and pushed oil through the filter to move the prefilled oil up into the engine?
Oil changes (and chassis lube) were every 2000 miles.quote:
Originally posted by Filter guy:
[QB...I also believe, if someone's got the owners manuals, that oil changes were every 1,000 miles....
[/QB]
