How many of you add oil to your oil filters before you install them? Are there pros and cons in doing this? Thanks.
Thanks.quote:
Originally posted by Big Jim:
I do it on cars that you can install the filter without spilling the oil you added to the filter.
It is beneficial because you don't have to wait as long for oil flow after an oil and filter change. It may not help much, but it doesn't hurt either.
quote:
Originally posted by Filter guy:
For those that prefill....
Caterpillar had/has a TSB out that forbids mechanics from prefilling their oil filters.
Have you seen how big those filters are......talk about having the pump fill a filter.![]()
Wanna know the reason..
Alright i'll tell..lol
The oil you put into the filter especially on the "clean" side has contaminant in it. Even from quarts, gallons, drums..whatever. Caterpillar wants no ingested contaminant from fresh oil down the center tube of the filter.
Now before anyone starts..ask Cat. They've done extensive testing..
why?quote:
Originally posted by kanling:
Even if new oil is a little dirty, I'll take dirty oil over no oil at all.
You don't have to fill the new filter to the brim, just let oil soak into the media some.
This is a question I have wanted explanation on for a long time. I bought the Noria book on choosing oil and a filter, and the book says the same thing.. some do not want the filter filled because oil from a bottle is "dirtier" than some obscure specification. What does that say about pouring the oil down the fill hole, and over the cam, valve train, etc.? Could this also lend validity to the oil becoming more efficient (smoother engine, better mileage- There are lots of posts here indicating something happens with time and mileage indicating the oil is "better" after a time) as it is "run in"? BTW, I fill the filter if I can get it on without making a mess, or wasting the fresh oil.quote:
Originally posted by Jonny Z:
From another thread...
The oil that gets poured down the fill hole runs to the crankcase before it gets pumped through areas with tight clearances and delicate surfaces. The combination of soft materials and tight running clearances make journal bearings more subceptable to immediate damage from contamination than other parts of the engine.quote:
People report lower metals in oil run for more than 2000 miles. I suspect that what we are seeing is not an oil phenomenon, but an oil filter phenomenon.quote:
