Added Lucas Upper Cylinder Lube
Michigan
I added 1.5 ounces/gallon of Lucas Upper Cylinder Lube. 20 HP Briggs V-Twin Definately quieter tappets. I was getting an oil temperature of 200*F at the bottom of the sump...today the temp was 180*F at the bottom of the sump. Too soon to make a statement....but hopefully encouraged. Seems like the product performs. Spark plugs look fine.
Pete591
Michigan
This is a gasoline additive...an upper cylinder lubricant...not an oil additive. The claim is it is an "upper cylinder lube...where oil can't go" It lubes rings and valve seats. If it can do this well that should amount to less friction and reduce heat. I need a few more temp measurements to see if I am consistantly getting a reduction in oil temps.
Somerset County, PA
 Originally Posted By: tpitcher
Love the tests - keep 'em coming!
Pete will have THE most thoroughly tested lawn tractor in history by the time he's done!! \:\!
Pete591
Michigan
Soon to come...testing the Amsoil EaO Oil filter vs. the Yellow Briggs Extended Life 2x....looking at engine temps...I figure should give the same temps as flow ought to be the same...we will see...
ON, Canada eh?
I'm going to test this myself on the JD. I'm also currently running 4oz / 10gal of MMO in the tank it boy is the engine quiet/smooth. \:\!
Canton, GA
I'm going to test this myself on the JD. I'm also currently running 4oz / 10gal of MMO in the tank it boy is the engine quiet/smooth. :!
Huh??....... (just bustin your chops stevie)
Pete591
Michigan
All yer JD guys talks like that!
Canton, GA
