When engine is cold, overflow bottle is dry. As engine warms, some coolant enters the (non-pressurized) overflow bottle through bottom orifice. Not much coolant in there, even at operating temp. This coolant makes the bottle bottom feel quite warm, but not very hot.
Planning to add 50/50 coolant and distilled water to overflow bottle, but thought it best to do so while there's already some coolant in there, so as to avoid an air gap in the overflow bottle hose. Intend to run engine until coolant enters overflow bottle, then shut off engine and add coolant before overflow bottle empties. Concerned that room-temp coolant could cause problems as it gets drawn into the warm (albeit cooling) engine.
Which option is best?
1. Fill overflow bottle with engine off but warm, while there's still some warm coolant at the bottom of the bottle.
2. Fill overflow bottle when engine is cold and overflow bottle is dry.
Also, any advantage to adding the coolant while the engine is running? (Would rather not, if possible.)
