3.5L SOHC V6 VTEC,FWD/AWD
5sp Auto, 260hp
OEM air filter - original
Toyo Roki 15400-PCX-004
Oil Fill 4.5 qts
Note: 4 oz LC/ 4oz Valvoline Synpower added at fill. 2 oz LC at 2 & 3k. 1oz Valvoline at 3k.Used #131(recomended dosage) on most tankfulls.
Overall, report seems good and motor seems to like this oil. Only disappointment is the low flash. Dunno where the potassium reading is coming from. Waiting on Terry's read.
As always, comments are appreciated.
5sp Auto, 260hp
Oil Fill 4.5 qts
Current fill is same but additives cut in half. Using the pint sized Purolator+ oil filter as well. Will be using Fuel Power on gas instead of #131 this time.Most likely do the same OCI again.code:
synergyn synergyn current
total mi 11125 15089 19471
al 7 4 3
Cr 2 1 1
Fe 25 23 16
Cu 61 64 32
Pb 1 3 1
Sn 0 2 0
Mo 81 94 123
Ni 0 0 0
Mn 1 1 0
Ag 0 0 0
Ti 0 0 0
K 0 0 2
B 65 56 99
Si 6 12 11
Na 3 3 5
Ca 2098 2915 2223
Mg 5 6 47
P 877 1172 753
Zn 939 1396 880
Ba 0 0 0
Sus Vis@210 = 55.5 56.6 55.5
Flashpoint = 375 360 365
Fuel % = < 0.5 1.5 .5
Insolubes = 0.5 0.4 .3
TBN = 3.7 3.6 3.1
