They're precision manufactured to exactly the wong size.Goes to show you fancy CNC and such doesn't always mean accurate. You'd think they would at least QC or check every 10th part that comes off the machine.
Machining centers are not CMM’s. And machine time is expensive, no manufacturer is going to run a painstakingly long Reneshaw program to “check” each part. You also have to account for tool pressure, and how it will affect your finish as well as your size. Sometimes your 0.005” re-cut ends up being 0.006-0.008 and now you’re completely out of tolerance.The main important thing nowadays that can make all the "wrong size" stuff look like baloney. Is machining centers of all sorts can be equipped with inspection probes that check every part, and if it needs more material removed it does the automatic adjustment and recuts it. So that alone makes one wonder what is really going on. I have in the past done macro programming for just that sort of function.
Yeah I guess your behind the times this was 6 years ago. What is more expensive than machine time? A ton of scrapped parts.Machining centers are not CMM’s. And machine time is expensive, no manufacturer is going to run a painstakingly long Reneshaw program to “check” each part. You also have to account for tool pressure, and how it will affect your finish as well as your size. Sometimes your 0.005” re-cut ends up being 0.006-0.008 and now you’re completely out of tolerance.
What they’re doing is using tool life predictions on the CNC to automatically compensate for tool wear while performing spot checks with a CMM and/or other specialty checking fixtures on every X part. Tooling going into the machine is first set up on a pre-setter. They have it down to an almost perfect science.
Yep, Hyundai wanted to give me only a shortblock when my wife's 2013 Elantra galled up the piston skirts and threw aluminum through out the engine. First sign is massive lifter noise and bad performance, as they become starved for oil. The owners should start a Facebook group and obtain a lawyer for a class action for full longblocks.Sounds like crankshaft rod bearing journals were not made flat/tound, they have a crown or are out of round (on engines made at the E. Liberty, OH plant), and damage rod bearings until they fail, launch metal, spin the bearing, throw a rod. Potentially an H/K Theta 2.4 event… Bad news is, Honda wants to do short blocks as a repair-we all know what happens to all the metal when bearing damage occurs-it goes EVERYWHERE!
I've got many years in all sorts of machinist work experience how much do you have?
Some set ups if you remove the part you can not reinstall it to recut it on the CNC, and then the cost goes up like crazy to manually machine it to fix the issue. Had a part one time that took almost 2 days to reload to cut, a specialized casting, and it was from some other person.
This shows what I am talking about, on machine inspection.
Bout the same here though I have done some other jobs along the way though. There where no CNC when I started, some tape jobs though with binary lights blinking at you talking tape data .Been a machinist since I was in high school thanks to School to Work, thankfully my high school is one of the few left with a stellar shop class.
I’ve seen enough CNC’s with enough slop they couldn’t cut a circle within 0.001”, I and any other self respecting machinist would never trust OMM as a final word.
Also CNC/production environments are BORING. Left that world last year.
No more than 300rpmBout the same here though I have done some other jobs along the way though. There where no CNC when I started, some tape jobs though with binary lights blinking at you talking tape data .
Yeah been around junk cnc as well. But been around some that have no issues working in the micron range too.
We did ball bar and servo tuning for circular error, and constant probe calibration, like every day some times more.
Watch that stock hangin out the back, I saw a fellow almost have his left arm cut off from that.
I am currently trying to decide how to handle this recall for my Acura TLX. I really don't like the idea of my engine with 150,000 miles on it being torn down by the dealer. Would it be expected that if the bearings were wearing incorrectly that it would show up in an oil sample? I got a clean report at 137,000 miles.
VCM has been around forever now on the J35, and in much worse iterations before that caused a multitude of issues, however not bearing failure. The J35 is not a prevalent fuel diluter either, so I doubt those directly contributed to the bearing issue.Nobody really knows why these Honda rod bearings were failing. Honda blamed machining problems, but they only fessed up to a small percentage. Lots of folks outside of the chosen VIN’s have had bearing failure. What’s really going on?
I don’t know, but that doesn’t stop me from speculating.
VCM forces the engine to run out of balance.
GDI tends to cause fuel dilution. BTW, all these rod failures are on GDI engines.
10K oil changes + fuel dilution = bearing failure?
My response is to disable VCM, and go to 4K OCI using Valvoline RP. YMMV
He’s not doubting your speculation. He’s rebutting some of the things you said - and he’s right. The J35 even with DI isn’t a known diluter and previous VCM versions (VCM-1 and VCM-2) were hard on oil, giving varnish and sludge as well as carboned rings but no big history of bearing issues. It’s an issue on the 2018+ vans, which are VCM-3 and DI of course.Ok. You doubt my speculation. That's ok.
I doubt your unsupported opinion.
This problem is unforgiveable for Honda...my, the mighty have fallen. We'd expect such issues with Ford, GM or Stallantis as normal. Even Toyota is plagued by such problems...Taking a shot in the dark here, as there seems to be a lot of knowledgable people on this board.
Acura is recalling thousands of MDX's due to crank issues "During engine manufacturing, some crankshafts may have been built with improper connecting rod journal dimensions, resulting in increased friction between the journals and their bearings. This increased friction could lead to accelerated engine deterioration and possible failure due to a lack of lubrication and excessive heat.”
This is from Acura
What I am wondering is what exactly is the issue? The above to me is "for the masses" but for those who know engines need to know exactly what is wrong with the crank.
Some Acura/Honda techs might not answer, and some might not even know but by now some of the techs must know the answer to the question - i.e. whether the crank was inadvertently ground over or under and therefore not well matched to the bearings or if it really was ground 'out of round' and if so, how new bearings are going to help.
Thanks
