All,
I know all '96+ cars are OBD II and that there are dozens of readings that can be seen in programs like AutoTap. My question is this: how accurate do you think the readings are? For instance, if you were to place an oil pressure guage on a car would it read the same as the computer? (assuming it is a quality guage/install). You can get rpm, oil temp, oil pressure, coolant temp, intake air temp....etc. I would think that due to emissions, knock, etc that the ECU would have to be pretty accurate.
What does everyone think?
