Originally Posted by Gokhan
Are you claiming that an improved-quality PAO base stock that is thicker at 100 C and has a higher viscosity index will have a lower viscosity at 150 C than an inferior PAO base stock that is thinner at 100 C and has a lower viscosity index?
Why is "regular" SpectraSyn "inferior"? It simply has a lower VI. It's main claim to fame is low volatility when combined with improved low temperature performance as per Mobil. This is obvious when you look at the rest of the data like KV -40, CCS, MRV:
SpectraSyn 6:
KV -40: 7,800cSt
KV 40: 31cSt
KV 100: 5.8cSt
CCS: 2,260cP
MRV: 7,310cP
HTHS : 2.08cP
SpectraSyn Plus 6:
KV -40: 7,400cSt
KV 40: 30.3cSt
KV 100: 5.9cSt
CCS: 2,247cP
MRV: 6,243cP
HTHS: 1.86cP
And this behaviour is the similar when you look at the 4cSt products:
SpectraSyn 4:
KV -40: 2,900cSt
KV 40: 19cSt
KV 100: 4.1cSt
CCS: 910cP
MRV: HTHS: 1.46cP
SpectraSyn Plus 4:
KV -40: 2,430cSt
KV 40: 17.2cSt
KV 100: 3.9cSt
CCS: 733cP
MRV: 2,023cP
HTHS: 1.24cP
For both ~4cSt @ 100C bases the HTHS of the higher VI "Plus" product is lower than the lower VI "regular" product, the same as with the 6cSt products. So, rather than assume that Mobil's data sheets are faulty, which seems ridiculous, I think the obvious answer here is that the higher VI PAO base oils in the "Plus" family respond different under the HTHS test than the "regular" PAO bases.
If you like, I'd be more than willing to reach out to Mobil and ask them.
