Will you replace the timing chain at some point? There any recommendation from the factory on that? It stretches, jumps/breaks at some point, yes? No?
What I've seen and asked around tells me if you change the oil and not rev it to redline each shift, you can expect 300k+ miles. If your a redline person, look around 190-250k.
There is a Lab company here that had 15 Corollas (2 got destroyed in accidents
) for picking up Lab tests/drug screens and they are right now around 200-230k with no problems as far as timing chains. 1 has had to have it's tensioner replaced (I think it was a bearing that went out).
The biggest problems they have had with the Corollas?
1. Windshields cracking due to rock chips. Like 2-3 a month!
(mine has had 2 chips and I see a semi I stay way back...still got 2 chips and had them repaired)
2. Terrible tire life. The drivers show no mercy on tires and they seem to use a set of tires out in less than 25k.
No matter what brand. And the tire dealers will not warrenty a 70k mile tire if used in a business. (I did not know that)
3. Heater/AC fans inside the outfit. Seems that every one has had a speed or the whole motor go out.
4. CV boots. Outer ones esp the left side. (wonder why the left one?)
Other than those, they change the oil every 7,000 miles with QS 5w-30 dino (with a white oil filter with no markings
) at a local shop, Change the air filter out every 35k, rotate the tires every other Oil change and drive them up and down the Wasatch Front. I don't think any of them has had the valves checked. Maybe plugs every 100k?
Most of the fleet is 2001 with 4 of them 2002.
Oh, and on everyone the drivers seat is toast. The fabric is not up to people getting in and out lots of times. Plus the springs seem to wear out. They are in the process of rebuilding the seats in every one.
I asked one of the drivers (we use them for Drug Screens) when they are planning to get new cars and he said the owner is going to keep them until they cost too much to run. I figure that they will make 400k on them before he gets new rigs.
I guess they were looking at little trucks but the gas mileage will keep them in small cars.
This fleet is one of the reasons why I looked at and picked a Corolla. I know how my wife and I take care of and drive a car. Looking at the labs use, mine should last 400k! And at 25-30k per year, I'll see if I can make it soon enough!
Take care, bill
