Hi all, I had my struts changed last summer and had never gotten the alignment done after. Everything seemed fine, but I got new tires and wanted to make sure they wore properly as it was my understanding that even though it was driving properly that subtle differences may have an affect on the tires.
First question. Is that sound thinking or should I have just left it be to save money?
Secondly. I had to get an oil leak fixed and I brought my car in for service and had told the guy to check my alignment and to go ahead and fix it if it was needed. Well, when they called me about my repairs his story changed a bit. He said it's 35.00 dollars just to check and see if even needs an alignment as checking is half the labor. At that point I just said go ahead and check and do the alignment if needed at that point.
So, I have my printouts of the before and after and I'm wondering if it was worth it. The only numbers that changed were toe and setback.
Before:
Toe Left .22 Toe Right: .03
Total Toe .25
Set Back .32
After:
Toe Left .05 Toe Right .05
Total Toe .10
Set Back .26
It's an 01 Sentra
I didn't have a chance to talk to him when I picked it up as he was with another customer. I had talked to him in the past about tires and alignments and he definitely knows his stuff so that's why I came back to him when it was time to get some work done, but now I'm not so sure if the business practices are fair and I'd like to hear some opinions on that and more importantly if those slight changes were significant?
I had wanted some other stuff checked out, but they wanted 37 dollars just to take a look at my front passenger pads and rotors as they said the parts would have to come off to diagnose. Is that common to charge just to figure out the problem? I haven't experienced that before, but they wanted to charge just to check things out and wanted 50 bucks for a break bleed. I think they do good work it just seems pricey to me, but I'm willing to hear that I'm wrong.
I just really need a good mechanic at a fair price.
Thanks!
Before:
Total Toe .25
Set Back .32
After:
Total Toe .10
Set Back .26
It's an 01 Sentra
Thanks!
