being the mechanicly inclined person that i am, i often wondered exactly how long it takes my engine to warm up to operating tempature. according to the oem water tempature guage, this is approximatly 3 minutes. i found this kind of odd that an engine can warm up this quickly.
when my engine is warmed up according to the oem guage, it runs at 191F.
i bought a aftermarket engine temp guage for an aircooled porsche and installed it by drilling a hole in the side of the cylinder head and using thermal epoxy to enclose the sending unit into the aluminum head. according to the cylinder head tempature guage, which measures the alumimum tempature, NOT the water, it takes approximatly 15 minutes of idleing to get to the fully operational tempature of 200F. i suspect this tempature is higher than my water temp of 191F because the radiator fluid is not 100% efficent at removing heat, so the physical engine tempature is awalys going to be hotter than the radiator fluid.
when driving around town the water temp remains pegged at 191F while the physical metal tempature fluxuates between 200F and 215F.
when under power at 85mph with the radio blasting and the a/c on max with my headlights on (to load the engine as much as possible) the water temp still stays pegged at 191F while the cylinder head temp climbed to 235F.
so, this has made me re-think the warm-up time it takes before you can punch an engine hard. most people drive their engine easy for the first 5 minutes before they drive hard, or redline and such. i would suggest waiting a bit longer, say 15-20 minutes of easy driving before you go out and run through the gears.
it takes amlost 5 minutes just to get the cylinder head over 100F, although the water temp is already at 191.
