A/C blows warm...
Fargo, ND
Hey group,
Car is a 1994 Lexus ES300 ------
Here's the problem - my A/C is blowing warm as if it is not cooling at all.
The A/C compressor is running and the clutch is engaged but it does not cycle.
I have already replaced the expansion valve last summer, then had the system sucked down, it held great vacuum, and recharged. Worked OK all last year, now all spring it has been getting worse.
I bought one of those recharge kits with the gauge and the low side shows proper pressure and is 'properly charged'.
I also had an A/C line replaced last year at a shop.
I checked codes on the HVAC unit - there are none logged.
Any other things I can check myself before I take it in and probably get a $1000 A/C job?
Luckily I have a 2nd car with great A/C so I am not in a huge hurry.
Thanks for the ideas -
Andy
