- Messages
- 11,284
- Location
- Spring HIll
Just changed our 99 Toyota Sienna V6 today and let the oil drain for about an hour from a warm engine. I've been using M1 5w30 for 3300 miles and will send out UOA tomorrow, results to follow shortly....
I use an aluminum 6qt tin pan to drain the oil in. Today, I noticed a silver-dollar sixed mound of black sludge and goo. Also, the bottom of the drain pan was moderately covered with large grains of ???...I don't know what they were, but they looked like large salt crystals. I always let the oil drain for an extended time to get as much junk out of the bottom of the oil pan as possible. (I think I succeeded today!). I've never seen so much junk, ever, in the drain pan as I did today!
I've run 4 Neutra treatments with Chevron Supreme prior to going M1 a few months back. By the 3rd Neutra treatment, it took almost 1000 miles for the oil to start chaning color as, what I thought, most of the crud had already been flushed out.
The motor oil on this car has been changed at least once every 3K , it has 45K on it now. The last 10K has seen MANY changes.
By the looks of things, it looks like this engine is falling apart, or at least feels that way! What gives? I bought a 96 Saturn that needed TLC with the oil changes and sees no where near as much junk in the drain pan at oil change time...
Thanks for reading my long message. Any suggestions on what is coming out of the engine? Are these motors THAT prone to sludge? I guess I'm looking for a vote of confidence that it's worth spending the time and $$ on this engine to make it last. I should have kept the Windstar if I knew how much problem this vehicle would be! (Ok, maybe not...)
Thanks,
Mike
![[Cheers!]](/forums/graemlins/cheers.gif)
![[Smile]](images/icons/smile.gif)
