Wow man, hang on to that '99 Taurus as it's the last year of the oval design, and the probably only made several hundred thousand of those :^) (We have a 93 and a 99).
I am currently running 3 qts of Mobil 10w-30 with 2 qts of Mobil 1 T&S in both cars. I did try Delvac 15w-40 in the 93 with the Mobil 1 T&S for one interval, and while it ran very nicely when warmed up and always ran quieter than 5w-30, it made for a lumpy idle when cold. I wish I had found this site earlier as I didn't start using a synthetic blend in the 93 until over 100k miles, and while it's still running well at almost 178k miles it does consume about a quart per 1k miles. The 99 now has 75k miles and doesn't burn any. I had always used a dino 5w-30 previously, typically changed at the Ford dealer.
The tranny seems to be the major weak link so plan on a full flush at least every 30k miles and preferably sooner. I use just enough Lubeguard red to stop what seems to be called 'torque converter shudder', where it vibrates at a stoplight. Use too much and it can start slipping. We had zero problems up to 75k miles and then went thru a starter, headlight switch, two fuel pumps, wiper switch, water pump, air conditioner, radiator, engine and tranny oil pan gaskets, and a couple of O2 sensors in the next 100k miles, and it's now a symphony of rattles. The 99 has a stiffer chassis but is a bit heavier. We were amazed that the 93 would get 28 mpg cruising at 70 to 75 mph with air, six people and a full trunk, and the 99 has hit 29 mpg. We ended up sticking with the Taurus as it seemed to be the cheapest solution for carrying six people.
