For probably the last time, I changed out the timing belt and water pump on my old Sienna. The belt and cooling system looked good, no major issues except a stuck bolt in the engine mount support. Water gets down inside the support and corrodes the aluminum against the steel bolt. Anyway, I bought a new support and bolts and with a little destructive demolition I got the support removed.
No leaks and the engine started up fine. Getting the belt on properly is a bit difficult since you can't directly see the rear sprocket timing mark. You have to use a mirror and making sure there aren't parallax errors is somewhat fiddly.
So it has a new timing belt, new idler pulleys, new water pump and new accessory belts (Aisin kit and Toyota/Mitsuboshi accessory belts). We'll see how much longer this old vehicle will last, the transmission is starting to act weird at times and that may be more trouble to fix than it's worth. I don't know
The pictures below are just the water pump part of the work as I was crunched for time getting it back together and didn't take any pictures of the belt. But that was nothing out of the ordinary.
