Originally Posted by fdcg27
After only twenty years and 222K this thing is using oil?
LOL!
We've had a couple of 200K four cylinder Hondas and neither showed any appreciable oil consumption but both were on short drains by me and both were also redlined regularly. Both were also sticks, which made redline fun and may have helped in keeping the rings free.
The question in this case is whether the engine is badly worn or is merely suffering sticking rings.
Certainly replace the PCV valve, but there is also some chemical intervention you could try with Kreen and/or Valvoline's very costly magic carbon dissolving oil.
If these efforts produce no positive results, run M1 HM 10W-30 and add oil as needed.
There was a guy here who actually did a field rebuild on an '85 Civic with 400K due to the car blowing too much smoke for CA emissions and his not wanting to part with it, but I'd doubt that you'd want to go to that extreme.
Originally Posted by berniedd
My 1998 CRV with only 70,000 miles began consuming oil at the 17 year old mark. I pulled the spark plugs and #1 and #2 were oily at the tips. Verdict: leaking valve stem seals, likely due to age (yes, age causes rubber to get stiff). The seals were changed and that fixed the issue. I'd bet you are in the same boat, but likely you need new piston rings too. If you do get the rings changed, then you might as well replace the crankshaft and conn rod bearings too. One thing leads to another. Considering the car's age and mileage, may I suggest replacing only the valve stem seals. That can be done without removing the cylinder head. If that improves things, then you'd have bought yourself more life from the engine with reasonable expense.
Checking the PCV is a good idea. It is right there in the middle of the engine valve cover edge.
I had a mechanic replace the valve cover gasket along with other things when I first bought it (alternator, pcv, water pump, belts, starter, Sparks, wires, fuel pump, fuel filter, radiator, valve adjustments, etc). The car does stall of o brake to hard. Like it loses spark.
