JHZR2
Staff member
This is a UOA report on my mother's 97 plymouth breeze. It sees almost entirely 5 block commutes multiple times a day, as she is a teacher and lugs around a lot of books, etc.
This UOA period, there was quite a bit more highway driving, as my father was using the car when it was cheaper to get 32 MPG on regular gas than 36 MPG on diesel.
Even when getting the 5 block comutes, the car was taken on weekends occasionally for 150-200 mile trips, which contrlled moisture.
The car used a bit more than 1qt over this OCI. Admittedly, the oil was checked when it was a quart down already, it wasnt a gradual loss. So, Id venture to guess that these numbers can be as much as 25% low (1 qt in a 4.2qt sump). All the same, not bad at all. M1 5w-30 and this engine are good together... makes me think twice about if I want to try PP instead for the economy ($1.61 on sale) and interesting chemistry.
P.S. Sorry for everything not lining up as it should. The code formatting doesnt work as well as it ought to, I guess...
[ June 26, 2006, 07:56 AM: Message edited by: JHZR2 ]
JMHcode:
Sample Date 04/10/04 01/09/05 12/01/05 Current
Time on Unit 69259 74568 83044 91596
Time on Oil 5000 5309 8476 8552
Time on Fltr 5000 5309 8476 8552
Oil Maint. changed changed changed changed
Filter Maint. changed changed changed changed
CONTAMINATION
There is no indication of any contamination in the component.
Silicon 23 93 7.9 6.8
Potassium 0.0 0.0 0.0 0.0
Sodium 3.9 5.8 3.8 10
Fuel (%)
Glycol (%)
Water (%)
Soot (%) 0 0 0 0
Sulfation 90 --- 63 57
Nitration --- --- 65 100
WEAR
All component wear rates are normal.
Iron 16 27 8.1 21
Nickel 1.3 0.6 0.9 0.4
Chromium 0.5 0.7 0.2 0.1
Titanium 0.0 0.1 0.0 0.0
Copper 1.7 6.3 3.5 1.5
Aluminum 6.7 6.7 3.9 6.4
Tin 0.3 0.0 0.0 1.0
Lead 1.2 0.2 0.7 0.7
Silver 0.0 0.0 0.0 0.0
OIL CONDITION
Oil Type: 4.2 QTS of MOBIL MOBIL1 FORMULA SAE5W30
The condition of the oil is acceptable for the time in service.
Boron 176 133 53 39
Barium 0.0 0.0 0.0 0.0
Calcium 2889 2633 1469 2055
Magnesium 22 23 8.2 15
Molybdenum 79 77 129 72
Phosphorus 848 801 609 699
Sulfur 2242 2249 3960 2661
Zinc 952 929 629 763
Visc@40°C --- --- --- ---
Visc@100°C 11.00 10.9 10.4 10.9 10.9
Oxidation --- --- 70 75
