gathermewool
Site Donor 2023
I researched as much as I possibly could, (and still do from time to time) posted up on the subaru forums, and even spoke with the local service guy a few times about this issue to no avail...
Sorry for the long post, guys. I know the system is working so I'm not worried about my NOX emissions. I'm worried about the emissions test I've got coming up at the end of this year. I've tried to spend as little money on this as possible. I was doing well until I let the Subie tech convince me to buy the expensive Xducer...
This may only be coincidence, but the code was in last spring, early, and then went away when it got warmer. Code came back this past fall and has been around since.
Here's a brief synopsis of the situation, and what I've tried.
Early 2008: P0400 code (EGR flow malfunction) pops up sporadically. CEL is clear MOST of the time.
As code becomes more prevalent I start researching: Haynes RM, nasioc.com, lgt.com, etc.
1. While at NOT, the EGR control system was tested by manually increasing throttle. EGR valve opened properly. EGR control system ok?
2. EGR valve opened while at idle. Engine only slightly bogs down. Dirty EGR valve? Clogged tube?
3. EGR valve cleaned, new gasket installed. Engine now bogs down considerably when EGR valve manually opened at idle.
4. Replaced all vacuum lines as well as the MAP sensor filter (suggestion from some one on the subie forums.) CEL clears on its own and stays cleared for a while.
5. Fall, 2008: code comes back and does not clear. CEL on constant to-date.
6. Replaced leaking EGR tube after HT RTV "repair" failed
7. Subaru service guy talked me into buying a transducer, even after I told him that the EGR valve seemed to open just fine. He stated that some times, with an old EGR Xducer, it may open TOO much. Code has not cleared in the two months since I swapped them out. EGR system seems to operate EXACTLY the same.
8. Finally had some time today to do a few more checks.
a. Hooked up vacuum pump to EGR valve. Applied 10" vacuum. EGR valve opened immediately, and held vacuum constant for >30 sec. I did this 5 times for repeatability. All passed.
b. Checked resistance of ALL solenoid-operated vacuum valves, including EGR solenoid. All showed resistance ~40 ohms. HRM says 10-100 ohms is good. With car off, key to ON position, all solenoid connectors showed battery voltage.
c. Hooked vacuum pump up to upstream side of TB. Didn't seem to show vacuum on the gauge even after I open the throttle. Downstream side showed 0 vacuum before and >10" vacuum after operating the throttle. Not sure what this means.
