RAM on macOS and with Apple's M1 CPUs is a different animal if you're comparing to Intel-based, Windows PCs. Sure, more RAM is always better but 8gb on these machines is not a crippled, budget machine. You can buy a laptop at Walmart for $299, if not lower but a new MBA is what, $899 at the lowest ? No comparison between them either.I expect Apple to have better sense than putting out 8GB on a new Mac these days, they shouldn't be competing with eMachine or Walmart house brand.
Apple's current machines have the CPU, GPU, RAM, etc all on a single 'chip'. That said, buying add'l RAM or disk storage up-front is basically a rip-off, but you have ZERO choice at least on the RAM side. They are NON-upgradeable. We used to buy iMacs with the standard RAM configuration and buy add'l RAM ourselves to install but even that's not possible anymore.theyre being cheap. adding another 8gb of bog standard ddr4 isnt $200+ expensive and samsung has been making 16gb single chips for a while if im not mistaken.
Yes, that is more like the HBM style architecture and it is expensive to make, so they "cheap out" a.k.a compromise because it is faster and can manage with swapping. The problem is their architecture really shines with iOS system but not OSX based one.Apple's current machines have the CPU, GPU, RAM, etc all on a single 'chip'. That said, buying add'l RAM or disk storage up-front is basically a rip-off, but you have ZERO choice at least on the RAM side. They are NON-upgradeable. We used to buy iMacs with the standard RAM configuration and buy add'l RAM ourselves to install but even that's not possible anymore.
True and i know that its a unified package but apple uses two separate ram chips so its most likely a 4gbx2 and they combine together. but yeah i miss the upgradable apple computers of before.Apple's current machines have the CPU, GPU, RAM, etc all on a single 'chip'. That said, buying add'l RAM or disk storage up-front is basically a rip-off, but you have ZERO choice at least on the RAM side. They are NON-upgradeable. We used to buy iMacs with the standard RAM configuration and buy add'l RAM ourselves to install but even that's not possible anymore.
I just checked that setting in my Firefox and it was set to "true", so yes it seems to be the default setting.What's the name of this plugin?
BTW, Firefox is supposed to be doing this by default, but I guess it doesn't work all that well.
Enable or Disable Tab Sleep feature in Firefox browser
Learn how to enable or disable Tab Sleep feature in Firefox. You can turn on or off Suspend tabs option using Advanced Preferences.www.thewindowsclub.com
Not sure what you guys are running on your machines that take up so much memory. I use Chrome, and never have any issues on my 2014 Macbook Air with 4gb RAM, and my work machine is a 2020 MacBook pro with 16GB Ram. The work machine has Monterey OS and it's always running several tabs open at once. I'd stop using Firefox.
Rm requirements are pretty ridiculous for basic stuff now, web browsers do way too much high level client side stuff anymore it's ridiculous, this is my Windows 10 machine and it's currently using just under 16GBs, all I have open is a few tabs in edge and like a basic photo editor with a few things open in it, a few ms paint windows, solitaire, and a spreadsheet and a powerpoint.
