89 Ford Crown Victoria 302cid 5.0L. Each sample is about 6-7 months, over the winter in St. Louis area.
1st Column: Apr 04, 2700 miles, PNZL 10w30, A-Rx Rinse Oil. Blackstone
2nd Column: June 05, 2133 miles, Valvoline SynPower 10w30. Butler CAT
Aluminum: 14……… 5
Chromium: 7………… 2
Iron: 68………………… 19
Copper: 11……………… 9
Lead: 56 ………………… 12
Tin: 6 …………………… 1
Molybdenum: 63 …… 4
Nickel: 2 ………………… 0
Manganese: 0 ………… 0
Silver: 0 ………………… 0
Titanium: 0 …………… 0
Potassium: 3 ………… 3
Boron: 32 …………… 7
Silicon: 119 ………… 15
Sodium: 14 ………… 12
Calcium: 1746 ……… 1698
Magnesium: 51 …… 25
Phosphorus: 721 …… 748
Zinc: 752 ……………… 794
Barium: 0 …………… 0
Sus Viscosity: 54.8 …… X
Viscosity cSt @100C X …… 9.7
Flashpoint: 345 ………… X
Fuel: 1.0 ………………….Neg
Antifreeze: 0 ………….. Neg
Water: 0 ……………….. Neg
Insolubles: 0.5 ……….. X
Two things about the first sample. It was the rinse sample from A-Rx. Engine valve cover and oil pan gaskets had been replaced with silicone Fel-Pro gaskets.
The second sample is from my supply of Valvoline rebate oils I gathered. I would have let it run longer except I have plenty oil and I was worried about this UOA, since the first was so bad. This oil ran from Dec 04 to date. Used mostly in commuting about 9 miles on the highway.
The oil filter on this interval has a lot of gritty dark material in the can and in the pleats. Will the Auto-Rx continue to clean for several OCIs ? Actually this is about 6000 miles since the end of the rinse cycle.
Any Comments ?
Aluminum: 14……… 5
Chromium: 7………… 2
Iron: 68………………… 19
Copper: 11……………… 9
Lead: 56 ………………… 12
Tin: 6 …………………… 1
Molybdenum: 63 …… 4
Nickel: 2 ………………… 0
Manganese: 0 ………… 0
Silver: 0 ………………… 0
Titanium: 0 …………… 0
Potassium: 3 ………… 3
Boron: 32 …………… 7
Sodium: 14 ………… 12
Magnesium: 51 …… 25
Barium: 0 …………… 0
Any Comments ?
