N nucleardawg Joined Oct 8, 2008 Messages 208 Location The Peoples Republic of Washington State Apr 15, 2009 #1 the truck is a 4x4 with the 2.9l engine. The steering column moves up/down, and side to side. What needs to be fixed or replaced. Also the steering wheel is off center. The truck drives, steers, and stops fine. Just don't like the column moving.
M mechtech2 Joined Sep 5, 2006 Messages 19,478 Location Chicago Area Apr 16, 2009 #2 Under the dash is a mount - check that first for loose or broken bolts/nuts. You may have to remove a plastic panel.
