Quote:
I have read that tires should be chucked 6 years after the production date.
I think 6 years is more of a guideline to closely inspect the condition of your tires, not necessarily chuck them.
From the Sept 08 issue of motor magazine, trade secrets column;
Quote:
If none of your customers has asked you about tire aging yet, chances are they will soon. While concerns about tire aging have been around for years, recent media attention has turned it into something of a hot-button issue. The question basically is this: Should you discard tires based on a date code just like you would a carton of milk?
Dan Zielinski, Senior Vice President, Public Affairs, for the Rubber Manufacturers Association in Washington, DC, told me that his association "does not recommend a removal date for tires based on age because there's no scientific information to back it up." He explained that extensive studies of thousands of junkyard tires do not back up the notion that tires just deteriorate with time.
I asked Jim Davis, spokesman for Goodyear Tire and Rubber, about the problem of aging tires. Davis said: "There is no scientific evidence that leads to the conclusion that there should be a tire service limit. Different groups have studied it. Different companies have studied it. Tire companies have studied it. Nobody has come out with any kind of report indicating any kind of scientific data to support a specified tire service life."
NHTSA's position on tire aging is to "follow the manufacturer's recommendations. Some major vehicle and tire manufacturers have made recommendations about when you should replace tires even if they don't appear to be worn."
Some manufacturers would like to see tires replaced after six years, some after ten years. What about the idea called for by some safety experts of replacing tires that are six years old even if they don't appear to be worn? According to Tyson, "that six-year clock is pretty much at the conservative end of the various recommendations that are out there. The problem is there is a pretty wide range of differences depending on the region of the country you live in. On vehicles that have been in a warm climate like what you would find in the southern part of the United States, tire aging seems to be a greater issue than up in Maine, for example. For most vehicles that are used on a regular basis it's not an issue because you'll wear out the tires before they get old."
