Well, serviced my F150's 6r80 transmission this afternoon. Pretty smooth and easy, especially with the nice fluid transfer pump which I picked up for $8 from Menards. Was a little messier than I meant to be and since I didn't replace the pan with a drain plug maybe next time I'll suction the fluid out first to save the driveway. Two questions I thought of though...
1. Having a hard time getting it filled just right. How well do these trans tolerate over fill? I have heard they hold vacuum so I'd imagine there isn't anywhere for fluid to self-level... Then again, I've heard they don't like to be low, either. Haven't run it to full temp yet, but the hose going into my trans cooler was warming up despite ATF temps being in the 60C range. I do have the factory aux cooler as well as a remove filter plumbed in.
2. Using a Napa Platinum (Wix XP) 41085 on my remote filter. Changed it after two years. Pan and fluid looked very clean with minimal deposits or slug noted. Pan magnet was almost completely clean. What would be a recommended service interval for this filter? Its plumbed in as a full flow on the cooler circuit. I know the trans has an internal cooler thermostat but I don't know much else. I don't want to loose cooler flow due to filter restriction.
