This oil was in service for about 9 months including winter storage. About two qts of make-up oil was added. 8 oz of valvoline synpower oil treatment was also added. This 302 dynoed at about 300hp and gets run in all conditions from winter hunting to high speed highway in 100 deg weather. There is probably more hours on this oil then your average oil gets because of several weekends of slow speed fourwheeling.
Valvoline All climate 10w-40 + 8oz synpower additive
Miles on Engine 45000
Miles on oil 2745
Al 5
Fe 35
Cu 2
Cr 2
Pb 533
Sn 2
Si 16
Na 192
K 38
Mo 126
B 23
Ca 2194
Mg 125
P 981
Zn 1209
Vis 12.9
coolant Neg
Fuel dil Neg
Iron is high but that doesn't worry me as much as the high sodium and potassium. I hate trying to chase down little coolant leaks. I was surprised by the low Silicon considering that valvoline has about 7ppm to start with. Add that to a K&N filter and lots of dusty fourwheeling and thought I would see Si numbers in 20s at least. I guess I should quit saying bad things about K&Ns.
Who can guess what caused the high lead? The lab couldn't
The viscosity was on its way out of grade but I don't know if this is normal for old carbed stuff. There isn't many UOAs of old iron on this forum.
I'll probably run another interval on rotella 5w-40 and see what happens. Maybe add some magic coolant tabs. This bronco really needs a 351W anyways plus it doesn't owe me anything.
Miles on oil 2745
Al 5
Fe 35
Cu 2
Cr 2
Pb 533
Sn 2
Si 16
Na 192
K 38
Mo 126
B 23
Ca 2194
Mg 125
P 981
Zn 1209
Vis 12.9
coolant Neg
Fuel dil Neg
