6.7 cummins maxing out egts towing 4k pounds?
I don't know if it's the trailer or what. Maybe a brake is dragging, but it feels like i'm pulling a train even when the trailer is empty. It easily sustains 1000-1100 egt temps and if I try and run 65-70mph.
what are your egts unloaded? Where do you have your probe?
What are your boost/backpressure numbers when towing? Any smoke out the tailpipe when towing? It is very possible you could have a brake hanging up on the trailer.
650 unloaded is just right
Those temps would be high post turbo, but I don't think they are high at all pre turbo. A dyno run at Banks on a stock Duramax showed 300-400 degrees Fahrenheit drop across the turbo. If I remember correctly, the stock Duramax pre turbo is EGT limit is 1350F sustained and 1425F peak.
The boost Guage is inaccurate, but it's usually like 5-7 psi. I don't have a drive pressure gage. The boost gage works it just doesn't zero out.
we need details could you post all the missing stuff.
one line isnt enough to get a good answer.
Type of trailer,Trailer weight? how many axles? shape/design?
terrain, outside temp. etc. should have all been in the first post.
We dont even know your location or anything.. so..... :unsure:
Is truck stock?
question with no details = generic or inaccurate answer at best.
A general rule of thumb is 1250 * sustained temps is The limit. 1100* is high for that light of a trailer IMO.
OP, need more data to better help you. Do you know anyone with diagnostic equipment?
