quote:
Originally posted by boxcomp:
I was reading a thread on here about how 10w40 used a lot of VI's and breaks down and leaves deposits. Is the same true for a synthetic 5w40 such as the Rotella T I just bought?
A lower quality base oil combined with a wide spread results in an oil that will most likely sheardown a bit resulting in all sorts of "good" things...
Rotella 5w-40 is a group III 5w-40, and as such does have an amount of VII's in the mix, BUT it uses a very high quality base oil in conjuction with VII's that are very carefully selected (given it's an HDEO)
quote:
Originally posted by Palut:
From what I've learned here: Stay away from large viscosity spreads in dino oil
What defines "large"?
Would 15w-40 be "large"?
I take it you wouldn't approve of 25w-70?
