5w40 vs 10w30 in turbo volvo
Surrey BC
HiI'm new to this site ,but have been reading tis for about month now , anyways what I was going to post is how different vis. affect engine performance . Since graduating as auto tech. and working back in europe for Fiat in their racing div. I do know thing or two about engine performancce . So I have hooked up vacuum/ boost gauge on my volvo 850 turbo , yesterday I chenged engine oil ,went from Chevron delo 400 5w40 gr III , to nascar synthetic 10W30gr IV and V blend and instantly gain 2inhg of vacuum which is pretty significant,. How good this oil is ? I have no idea but reduces friction inside the engine I'll keep ti in for 5k and change it , this is my plan , Eric
driven2services
Administrator
Isn't there a difference in drag between the 40 wt. oil and the 30 wt. oil in the turbo bearings? Isn't that restrictiong the turbo's rpms and therefore the vacuum/boost? Ken
st. Louis
That's very interesting. Let us know if there is a noticable performance or mileage difference.....an oil analysis would be great too. [Big Grin] I've been considering a 5W-40 or 0W-40 Mobil 1 for my '02 S40. Dealer says use 10W-30, service book says 10W-30 is good up to 104degF, but the owner's manual (printed by Volvo in Europe) says use 5w-40 for a much wider temp range than 10W-30 which is not reccommended over 86degF....how is that for conflicting advice?? [I dont know]
Dixie
Mormit, The oil specs for most engine are written with the assumption that you are going to be using an average quality, or even below average quality, petroleum oil. I have found with Amsoil that you can generally go one SAE grade thinner than what the engine manufacturer recommends in a petroleum product. Running the low viscosity synlube reduces your oil temps, so the oil doesn't thin out as much. In addition the film strength of PAO/Ester synthetics is significantly higher, so you don't need a thick oil to get excellent wear protection. I have been using and recommending this approach to my customers for the past 17 years in a variety of applications. Mobil 1 is an excellent synthetic oil for the price, but I'd actually go with their 0w-30 for the best performance in your Volvo. At operating temp, the Mobil 1, 0w-30 is about the same viscosity as the Amsoil "XL 7500", 10w-30 you have been using ....It will work fine in your engine. TooSlick
