5w40 Syn and 15w40 any type.
Cloverdale BC
Why do most "big oil" companies have a 5w40 syn and not a 15w40 synthetic. I have delvac1 5w40 right now in my ford 6.0l and runs the best ever. Am I hurting anything by using this weight. I understand it is still a 40 weight at operating temp. But why the different weights when cold. Synthetic vs dino. And I know others make a 15w40 Syn. but could someone explain to me why the they use the 5w40.
A 5w is going to flow better than a 15w when its cold. Synthetic or otherwise.
I have a Cummins in my Dodge. Cummins recommends a conventional 15w40 for all but the coldest conditions. IIRC anything lower than 0 degrees they recommend a 5w-40 synthetic.
If you want to run synthetic year round it won't hurt anything. I've seen a bunch of used oil analysis for the CTD and it seems the be pretty easy on oil.
Since a cold night down here near Seattle is about 25-30 degrees I won't be running synthetic.
Because a 5w40 syn could be a 15w40 if tested that way. Dirty little secret that many here don't seem to remember is that a syn oil can be technically a straight weight and a 10w30 ( amsoil) or many other combos and be sold as different products for PROFIT....
I note a popular fuel additive seems to have started doing that here recently...
'splain the fuel additive thing to us.
Unless you check the specs, you don't know what you are getting anyhow. Case in point---Amsoil 15-40 vs. Rotella T Synthetic:
Amsoil Vis. @ 40 C. is 89.7
Rotella Vis @ 40 C. is 90
Amsoil Vis @ 100 C. is 14.4
Rotella Vis @ 100 C. is 15
They are basically the same weights yet one is a 15-40 the other is a 5-40.
Interesting observation Todd. I did a little checking, for example:
Quaker State 5w30 has very similar rates to another vendors 10-30, and similar rates again to another vendors 5-20. I assume base stock has a lot to do with both the viscosity rating, and it's spread across the temperature scale. I wish there was a better way of determining what happens outside of the scale?
