To the OP:
By running 5W-40 instead of 5W-30 do you think the engine will last longer? If the oil and filter are changed out at manufacturer's specified intervals, the engine will outlast the body.
Yes, in South Florida, the engine can/does get hot in traffic where most of my driving
is done. I don't trust a 30 weight in a 100K mile engine.
The only reason to run thicker oil in that car is if you take that car to the track for some really spirited driving.
That is a matter of opinion, you are in the minority if you read the whole thread.
GM knows that thicker oil protects engines better by virtue of the high performance Camaro and Corvette. Those engines spec a 5W-30 oil but GM specifies in the manual that if you are going to track race the car, they recommend running Mobil 1 15W-50.
I actually used Mobil 1 15W50 in my last Eldorado Northstar, a 1995 model
70,000 miles with it, ran great and got 28mpg on the highway
Morale of the story, run 5W-40 in your Caddy if you want, the engine won't last longer. You fuel economy might not be quite as good, but it might be insignificant. If you plan to take your Caddy to the track, run a thicker racing oil.
Well thank you for giving me permission to use the oil I like
But there will be no racing, so no need for a racing oil.
