You have a 110,000 on a Honda with dino oil and MOST IMPORTANT - regular oil changes, why change now? Keep doing what you are doing and the car will rust apart before the engine starts to wear out. There is no benefit to changing now, except to the oil company you by the oil from. There is a misunderstanding about pumpability(sp?) Just because synthetic oil pumps at -50* when dino oil has problems, does not mean it pumps better at 32*, it is not a linear scale to compare, it is only measurable at the extreme end. If you live in the Upper Penninsula of Michigan and you park your car outside all night when it is -30* w/o wind, then you might have a case for synthetics..if the car was newer. You have a great car that I am guessing has been running great so far with 110,000 miles(like all Honda's), don't jump into the hype of "better oils" now, just change them regularly like you have been and enjoy another 110,000 miles if you still have it.
